08-25-2009 08:06 PM
I just installed TestStand 4.2 and SQL Server Express on a brand new Windows XP computer. In TestStand, I set up the "Database" property so that it tested connection successfully. But when I open the Demo/C/computer.seq file to test, it is giving me error in logging the result. On-the-Fly Logging is not enabled.
The following is the error message I am receiving.
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Schema: Generic Insert (NI)
Statement: UUT_RESULT.
Description: Invalid object name 'UUT_RESULT'.
Number: -2147217900
NativeError: 208
SQLState: 42S02
Reported by: Microsoft SQL Server Native Client 10.0Description: Statement(s) could not be prepared.
Number: -2147217900
NativeError: 8180
SQLState: 42000
Source: TSDBLog
Error Code: -2147217900; User-defined error code.
Location: Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Is there something I missed in configuration?
Thank you.
Peggy
08-25-2009 08:35 PM
08-26-2009 10:54 AM
ha. no. didn't know there is a script. Can you give me some pointers on which script and how to run?
Thanks.
Peggy
08-26-2009 04:37 PM
PeggyC,
You can get detailed information on how to log to the database in the TestStand Reference Manual, they talk about SQL script files on page 113 which coresponds to 6-6. Hope that helps.
08-26-2009 04:57 PM
