NI TestStand
TestStand 4.2: error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database'
I just installed TestStand 4.2 and SQL Server Express on a brand new Windows XP computer.  In TestStand, I set up the "Database" property so that it tested connection successfully.  But when I open the Demo/C/computer.seq file to test, it is giving me error in logging the result.  On-the-Fly Logging is not enabled.
The following is the error message I am receiving.
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Schema: Generic Insert (NI)
Statement: UUT_RESULT.
Description: Invalid object name 'UUT_RESULT'.
Number: -2147217900
NativeError: 208
SQLState: 42S02
Reported by: Microsoft SQL Server Native Client 10.0Description: Statement(s) could not be prepared.
Number: -2147217900
NativeError: 8180
SQLState: 42000
Source: TSDBLog
Error Code: -2147217900; User-defined error code.
Location: Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Is there something I missed in configuration?
Thank you.
Peggy
(4,886 Views)
Did you run the script that creates the tables?
(4,884 Views)
ha.  no.  didn't know there is a script.  Can you give me some pointers on which script and how to run?
Thanks.
Peggy
(4,871 Views)
Accepted by PeggyC
PeggyC,
You can get detailed information on how to log to the database in the TestStand Reference Manual, they talk about SQL script files on page 113 which coresponds to 6-6.  Hope that helps.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(4,853 Views)
Thank you.  That page 6-13 is exactly of what I need to do.
(4,849 Views)
