NI TestStand
TSAPI error -17308 popup
I'm getting this error for every step, any sequence (including NI Example sequences), any model on my laptop.
Get this error multiple times if read/write local/global in a statement step.
Anyone run into this problem before?
George Zou
Message 1 of 9
(1,225 Views)
This looks like a screwed up installation to me.
I'd try repairing or re-installing.
Do you happen to have multiple TestStand versions on that laptop?
Message 2 of 9
(1,200 Views)
Thanks for reply.
There is only one version on my laptop - 2017 SP1 64bit.
The problem starts when I play with config settings.   I don't know which setting causes the problem since don't run sequence on this laptop (no hardware connected).
I'll try to repair/re-install.
George Zou
Message 3 of 9
(1,179 Views)
Before spending a lot of time repairing, you could as well delete configfiles.... IMHO all of them will be autocreated with default values if not available
Message 4 of 9
(1,178 Views)
Delete everything under C:\ProgramData\National Instruments\TestStand 2017 (64-bit)\Cfg
Still getting the same error for every step.
Repaired TestStand not working either.
Removed TestStand, and delete everything under TestStand folder.  Re-install TestStand.  Reboot.
Still getting the same error for NI example sequence.
BTW, run as admin makes no difference.
I can't format the hard disk.
George Zou
Message 5 of 9
(1,166 Views)
Sorry to hear you've gone through all this and it's still not working 😞
Considering you have uninstalled and deleted %Teststand64% on this PC before reinstalling, there is still the possibility, that the unsinstall left some stuff in the registry that the reinstall didn't overwrite.
AFAIK, TestStand version create their own set of RegKeys. Might be worth a try to see if installing another version like 2019 would work.
Additional though: do you have fancy IT Sec tools on this computer which might consider some components to be suspicious?
Message 6 of 9
(1,150 Views)
Thanks.  I'll try TS2019.
This laptop is a loaner from IT, but no fancy IT stuff.
George Zou
Message 7 of 9
(1,128 Views)
I installed TS2019.  It works.
Now I need to find out how to transfer my co-worker's license (perpetual) to my laptop.
Since our contract with NI has expired, we can't manage our license anymore.
Our license are not single-sheet license, so no serial#.
Don't know how this works.
George Zou
Message 8 of 9
(1,113 Views)
Problem solved thanks to NI support quick response.
Uninstall hidden packages and delete everything related to TS2017 worked.
Case closed.
George Zou
Message 9 of 9
(1,102 Views)
