NI TestStand
SequenceFileTranslator -> picking a specific one programatically
Hi y'all,
I have stumbled over the Sequence File Translator API in TestStand. Though it is not doumented too much, I think I can get the stuff to work using the examples and template.
My use case at the moment is being able to mass-convert a massive amount of proprietary XML files into seq files. Before getting into the nitty-gritty details of the actual conversion, I want to make sure, the "infrastructure" structure works.
The idea is to prgramatically open all XML files one by one and using a custom SequenceTranslator DLL for conversion.
Using one of the examples that NI provides, I can open the according example file.
What I haven't found out yet: how does the Engine determine, which translator to use? Does it try all registered translators until the first one returns CanTranslate = True?
(1,103 Views)
Accepted by Oli_Wachno
Yes, that is correct. The engine will try all installed translators in NI and User directories until the first one returns CanTranslate = True.
Anand Jain
NI
(1,074 Views)
Thanks for your anser and sorry to ask related/ further questions:
1.) which is the sequence, the callbacks are used in by SeqEdit?
"Debuggin" using the LabVIEW Example and Dialog Boxes, I see that
  • GetTranslatorCount
  • GetExtension
  • GetDescription
are called on starting SeqEdit.
Placing a dialog box in TranslateToSequence causes TS to hang when starting an actual conversion
Dialog Boxes in GetFileVersion and GetFileFormatVersions never appear
2.) [Personal lack of proficiency creating DLLs from LabVIEW]
Referring to the XML Sample Project from the TestStand example: there must be some kind of translation from XMLGetCalcCount.vi to the DLL Callback GetCalcCount
I suspected this to happen in the build spec, but couldn't find it.
(1,033 Views)
as for part two of my question:
typical case of wood and trees
(1,023 Views)
For future reference:
setting up LabVIEW to debug a SequenceFileTranslator, refer to
https://lavag.org/topic/6964-debugging-a-compiled-labview-dll/
Though the post is ~16 years old, it this still works as described here 😀
(890 Views)
