NI TestStand
Save the GOOP object reference for reuse in test sequence
I am using TestStand 2010 to execute LabView 8.6 VI's created by GOOP.
I am trying to figure out how to save the GOOP object out parameter from the GOOP VI's so that I only need to init the GOOP class once.
When I add a GOOP VI to a sequence the 'object in' and 'object out' parameter is grayed out.
The reason I would like to keep the GOOP reference is because I have instrument references stored in it, and instead of re-initialize the class every time it would be easier to pass the reference around.
Of course I could fetch the instrument references before closing the class and add support for initialize the class with existing intrument references instead, but first I want to be sure if there is a way to save the GOOP object reference.
Maybe I should mention that I think the GOOP object is a merely a cluster of data which has it's contents defined in a .lvclass file (but I'm out on thin ice on this topic, and it might be a little more complex then this).
BR
Martin
(3,701 Views)
I dont bother returning the the reference back to TestStand but keep it in memory by use using a FVG. But if you want to return it you could try Flattened to String.
Regards
Ray Farmer
(3,675 Views)
What is a FVG
/Bjarne
(3,633 Views)
Functional global variable
Rodéric L
Certified LabVIEW Architect
(3,629 Views)
OK, then it must be FGVSmiley Happy
Thank you.
/Bjarne
(3,625 Views)
