NI TestStand
Parallel tasks
After searching, I'm a bit lost about my project.
I need to continuously monitor signal coming from a PLC during test (eg Emergency stops, Doors...).
Communication with PLC is done by ModbusTCP (this is working).
What I want to achieve is stopping the current test/sequence if some signal change their state (interrupting the test).
I already tried with Sequence Call/New Thread and then check status in PostStep callback but no luck because somehow I'm not able to share data between "Monitor" thread and main sequence (even with station globals).
I can not use Labview due to project constraints so I cannot use examples I saw with RunAsyncVI and so on, but I can use DotNet if needed.
For sure I can devellop about my architecture if needed.
(Sorry for my poor english but it's not my native language as I'm french)
Noar
(3,713 Views)
I've been able to do the Sequence Call/New Thread and then check status in PostStep callback operation many times. If you can solve the sharing data problem that is a good way to go. I'm sorry I can't help with that, except I would try a very simple prototype that does nothing but share data between main and the thread. Have you tried passing a parameter by reference to the thread subsequence so the subsequence can write to the parameter and it gets copied to Main?
cc
(3,703 Views)
Thanks for your reply, I will try again with simple data sharing...
I'll let you know about results
Noar
(3,672 Views)
