NI TestStand
Extract data from Teststand UI StatusBar Control
Hi Guru,
In Labview User Interface Full-Features, i can see that it have StatusBar function,
i would like to know how can i extract the data from the StatusBar and show it as string indicator?
as you can see from the attachment, how can i extract the "administrator" and put it in string indicator?
(4,156 Views)
The status bar gets data from various locations.  Usually it comes in as UI messages.  However, some of it comes from the station options and in the case of "administrator" it is coming from the engine (technically a station global).
To get the current user in your UI you just need to simply call the Engine.CurrentUser property.  So use your engine reference and place down a property node.  Select CurrentUser as the property to get.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,129 Views)
I guess that technically if you want to follow the true form of creating a UI you should use the UI Manager controls and connect a TestStand Label Control to the Application Manager.  Use the ConnectCaption method and CaptionSource_UserName as the captionSource.
Something like the attachment.
Cheers,
jigg
CTA, CLA
testeract.com
(4,127 Views)
