NI TestStand
numeric limit test limits tab
How do I create a customized Numeric Limit Test type, where I can add a new tab (or a variable for example to the Limits tab) to the step settings?
So I need a fifth tab right next to the "Data Source" tab. Is it possible?
Message 1 of 9
(4,894 Views)
If you want to add functionality to or customize all instances of a particular step type, you can create a custom step type.
Message 2 of 9
(4,880 Views)
In TestStand, you can create custom step types as well as copy and edit existing step types
How Do I Make a Custom Step Type?
Message 3 of 9
(4,878 Views)
Yes, I can create my custom step types, and I can create edit substep for it. But in that case I see only an additional tab on the step settings, where I see a button. By clicking this button the code module of the edit substep will be called.
That is not the same as what I want. I want to edit the variables directly in TestStand, just like in case of the numeric limit test.
Madottati
Message 4 of 9
(4,874 Views)
Do you want to edit the variables directly in TestStand, which variables do you mean?
Do you mean edit LOW HIGH Limit from the Edit Substep ?
Could you provide us more information?
Message 5 of 9
(4,870 Views)
On the screenshot you see the step settings for the numeric limit test step type. There are 4 tabs. I would like to have a fifth tab with my variables, where I can edit the values of the variables of my custom step type. Those variables will be used by the code module in run time.
Message 6 of 9
(4,867 Views)
This is sounding like you should use a preexpression.
Message 7 of 9
(4,856 Views)
It sounds you are looking  for a built-in step type.
Please visit this idea
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Ability-to-create-user-built-in-StepTypes/idi-p/1...
... and if i am right, just give a kudo to this idea...
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 8 of 9
(4,842 Views)
Yes Jürgen, that is what I was looking for.
You have got my Kudo for it.
Message 9 of 9
(4,790 Views)
