‎11-11-2008 11:22 AM
‎11-14-2008 10:22 AM
I will give you my thougnt about your questions but id any other user will come up with further suggestion he will be welcome.
I agree with you prefering the first solution.
Basically you need a parallel process model and then you have ways for manage a synchronization ( notifier for example ).
When you say 'control all I\O in TS' you mean having an adapter (LV for example) called by TS that execute the I\O operation? I think this is correct.
For the last point, the most common architecture is to have TS as a manager for you test and LV code called as TS steps and not the opposte.
Bye
Clara
‎11-15-2008 08:29 AM - edited ‎11-15-2008 08:33 AM
In my opinion, you can use parallel model to run 12 sockets, but in sequence you need to control 3 sockets together, use statement/expression/notifier to justify in each fixture which socket is ready to occupy communication channel, this could be a vailable way to do. I do not suggest to use batch model to do this, it looks like all of things latched together then you need to wait to all 12 DUTs cooked.
I dont understand "control IO directly in TS", do you mean do it with out any adapter executable like Labview, I'm sure you can do standard IO control for standard instruments with IVI driver support. But actually IVI steps are also a type of adapter ^_^
‎11-17-2008 02:12 AM
Thanks a lot for your support. About the last item I know I was not very clear. I have a lot of digital IO controlling the machine and I will develop a step type in order to read and write these IO. But I am not sure that using TS as machine controller is the best solution. The sequences could become not very readable. Probably it could be better to have a machine controller like a LV state machine that manages all the machine and interacts with TS.
Thanks a lot.
Bye
‎11-17-2008
09:55 AM
- last edited on
‎09-10-2025
03:33 PM
by
Content Cleaner
logatto,
For a system of this complexity, we would be happy to help you develop an appropriate architecture for your application. If you would like to talk to an NI Applications Engineer to work through this problem, you can contact one by going to www.ni.com/ask
