Open multiple terminal in RasPi from TestStand
Hello all, i have a solution to communicate with RasPi through SSH in TestStand.
However, i need to open two terminals at the same time and write some commands to this two terminals.
Can anyone advise if there is a way to open two terminals at the same time?
Thank you.
XJ
(1,405 Views)
Accepted by 123xj
Guess you can achieve this runing the code for communication/ terminal with each Raspi in a seperate thread
(1,385 Views)
Hi Oli_Wachno,
I only have1 raspi and i would like to open multiple terminal from that raspi. Thanks.
(1,270 Views)
Same thing, just open the terminals to the same raspi instead of different ones
Seems you are trying to use the raspi as a shared resource, so make sure you are not running into conflicts between the executions
(1,259 Views)
