NI TestStand
Logging to different Databases on same Station
In the attached sequence i'm trying use the databaseoptions callback, to choose the database in use from within the sequence.
My result Processing options are also attached.
The problem is that the precondition on the step "Set DB1" in databaseoptions, is not evaluated as I expect !
If i check the value of "Parameters.ModelPlugin.Base.DisplayNameExpression" during runtime it acutally has the value "DB1", but still the step "Set DB1" is skipped !
any ideas ?
Message 1 of 8
(3,858 Views)
BTW I get the attached error when running the sequence.
Any Idea what it means ?
Message 2 of 8
(3,853 Views)
My first question is solved by this "http://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/330/thread-id/52945/page/1"
Precondition has to be:
Parameters.ModelPlugin.Base.DisplayNameExpression == "\"DB1\""
The error in my second message is still present
Message 3 of 8
(3,844 Views)
Maybe there is problem with file path - in error message it says, that it unables to open file "...\ModelPlugins". But this is folder, not a file... Maybe this is a problem?
Sincerely, kosist90
Message 4 of 8
(3,815 Views)
maybe - however i have no clue where that path is specified.
Message 5 of 8
(3,803 Views)
According to the error, you are trying to access a particular file, which may not be available on your PC or is blocked for some reason. This is because you are using a model plug-in sequence file that must be saved in the specified file path in the error dialog box. This is explained further in the following link:
https://www.ni.com/docs/en-US/bundle/teststand/page/creating-process-model-plug-ins.html
Just to confirm, is the following filepath not available on your PC? This is where your Add-Ons would be saved!
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Components\Models\ModelPlugins
Best Regards,
Jeneni
Message 6 of 8
(3,741 Views)
If i skip the step to override modelplugin in databaseoptions callback I can make the sequence define which database to log to.
Message 7 of 8
(3,721 Views)
that path is available on my pc
Message 8 of 8
(3,720 Views)
