NI TestStand
Calling Qt5 DLL from TestStand
I have a c++ dll created in Qt5 library.
1-) How to use in TestStand?
2-) Is there a problem using stl container(vector, list, map etc...) as a function parameter?
3-) Should I try calling only static function(C++) from TestStand?
4-) Is there a directory where it explains?
Thanks for any help
(2,756 Views)
Please remobe, wrong answer.
(2,721 Views)
If you're looking to use a container, I'd expect this to fall under a custom data type.  You can find some documentation here: https://www.ni.com/docs/en-US/bundle/teststand/page/creating-custom-data-types.html
For your third question, that's also another route you can take.  You can look at wrapping up your troublesome calls into a c++ function that uses more common parameters and let it handle the container within.  But, that seems like extra work versus creating the custom data type.
(2,710 Views)
