ā08-30-2005 07:11 AM
ā08-30-2005 08:02 AM
Is it a labview application (exe file) or the actual top level VI that you want to interface with teststand.
If, its the VI, then you can save the result arrays into some teststand Locals directly from your VI conector pane (assuming you are using TestStand 3.x). Then use some None Adapter steps types to act on each of your array data.
If your report is HTML, you can use the report option to insert a graph based on your result array.
Ray Farmer
ā08-31-2005 02:07 AM
ā08-31-2005 02:21 AM - edited ā08-31-2005 02:21 AM
Hi Holy,
Looks like you have a similar thread running http://forums.ni.com/ni/board/message?board.id=330&message.id=8088 and Santiago D. has provided a good example which should met your needs but I will be happy to provide maybe a simpler solve for you.
Ray Farmer
Message Edited by Ray Farmer on 08-31-2005 08:21 AM
