NI TestStand
problems with *dll files
I have created a *.dll from a*.c file in labwindows and I want to use this as modul in teststand. then when I execute my teststand seq the following error occure:
"could not find function "function name of my function of the *.c file" in the *.dll file". this error message occures although the function is in my *.c file.
is there a problem with converting *.c files in *.dll files in labwindows, or is it another problem?
how can I solve this problem?
regards
samuel
(3,650 Views)
You need to make sure you have exported your function correctly in you dll.
Did you use something like __declspec(dllexport) as part of you function syntax?
Regards
Ray Farmer
Regards
Ray Farmer
(3,649 Views)
Ray,
no my file doesnt contain a function like like __declspec(dllexport)
what does this function contain?
samuel
(3,647 Views)
No its not a function.
Your exported function should look something like this (being in mind this is a TS2.0 prototype, the different being the argument of the function eg testData and testError)
void __declspec(dllexport) TX_TEST MyTestFunction(tTestData *testData, tTestError *testError)
Regards
Ray Farmer
Regards
Ray Farmer
(3,642 Views)
