Initialize numeric array to a sequence of values
Is there a way of using TestStand array expressions to achieve the functionality that LabVIEW ramp by delta function has: https://forums.ni.com/t5/LabVIEW/how-to-best-initialize-array-to-sequence-of-values/m-p/3360005/high...
(3,784 Views)
Hi SumitN,
The attached sequence file uses a for loop with an expression to generate a similar vector to the ramp by delta but this begs the question: why wouldn't you just use that function in LabVIEW and output the result back to TestStand?
(3,752 Views)
Accepted by topic author SumitN
Hi SumitN,
If you wanted to do this within TestStand, rather than call a LabVIEW VI, it can be easily be implemented through a Statement step:
This can be achieved by configuring the expressions and looping as follows:
I've attached an example sequence with the above step included.
I hope this helps.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,743 Views)
@DJColeslaw
Creating a VI just to create a array of sequential values seems an overkill since this seems like a simple task which can be done in TestStand expressions. All I need is an array with an increment/delta of 1. The other option is to call "Ramp pattern by delta.vi" from vi.lib in program files but this will create a headache for me for deployment.
I wasnt able to open your sequence since its in TestStand 2017 whereas I am at 2016.
(3,728 Views)
@CharlieRodway
Thanks this was what I was looking for.
(3,726 Views)
No problem, glad I could help! Smiley Happy
(3,723 Views)
@SumitN,
Thanks for the reply and sorry for the version conflict! That definitely makes sense, I just wanted to understand your use case in case there are additional alternatives which weren't being covered. Sounds like a simple looping statement will cover it for you, though. Have a good one!
(3,710 Views)
