NI TestStand
Implementation of synchronization steps without using batch or parallel sequences
We are using a custom built process model based upon the sequential process model.
Do I need to invoke the Synchronization manager in order to use the synchronization steps when not using the batch or parallel process models?
(5,442 Views)
Accepted by JamesSid
All synchronization steps and operations (Locks, Rendezvous, Notifications, Queues, etc)  will work in any model or without  a model, except for Batch synchronization.
If you need Batch synchronization, your model needs to use the Synchronization>>Advanced>>Batch Specification step type to specify which threads are in the batch. Since you aren't starting from the Batch model, I doubt you need to worry about that.
(5,439 Views)
I was not sure since all examples are with the process models.
Do you know of an example that does not use a process model?
Thanks...
(5,436 Views)
I was able to get it working....
Thanks for your help...
(5,429 Views)
