11-13-2014 12:45 PM
We are using a custom built process model based upon the sequential process model.
Do I need to invoke the Synchronization manager in order to use the synchronization steps when not using the batch or parallel process models?
Solved! Go to Solution.
11-13-2014 12:51 PM - edited 11-13-2014 12:53 PM
All synchronization steps and operations (Locks, Rendezvous, Notifications, Queues, etc) will work in any model or without a model, except for Batch synchronization.
If you need Batch synchronization, your model needs to use the Synchronization>>Advanced>>Batch Specification step type to specify which threads are in the batch. Since you aren't starting from the Batch model, I doubt you need to worry about that.
11-13-2014 01:02 PM
I was not sure since all examples are with the process models.
Do you know of an example that does not use a process model?
Thanks...
11-13-2014 02:56 PM
I was able to get it working....
Thanks for your help...
