04-01-2013 02:09 PM
Hello
I am trying to install from Download on NI website Test Stand on a 32bit with Windows XP in my machine, but I keep getting the follow error:
.\IdFile.cpp(123): InstallerError 11006
Developer Error. The following errors were found in your ini file:
1. Missing Section: [Volume Id]
Correct the ini file and try again.
Found while attemping to read the volume id file.
Please HELP, I have a very short deadline coming around the corner.
04-02-2013 09:49 AM
Hey SBah,
To clarify, you downloaded the TestStand 2010 installer from ni.com/downloads, is this correct?
Also, what other NI software do you currently have on the machine, and has any NI software been uninstalled from the machine? We sometimes see this error when references to old NI products weren't properly removed during uninstallation. Another cause of the issue can be if you aren't running the setup.exe file from the hard drive of the computer you want to install it on, so if you have the setup files on a CD or thumb drive, I would recommend copying the files to the hard drive before installation.
I hope that helps some, and if you do continue to have problems with it, please let us know so we can help you get that resolved.
02-13-2014 10:48 AM - edited 02-13-2014 10:51 AM
I am having this same issue after uninstalling all NI apps from a PC that I am testing my deployments on. Help please? Thanks! 🙂
I tried to Recover from a Restore point but that did not help. Also ran CCleaner on the registry and removed NI links that were bad.
02-13-2014
01:43 PM
- last edited on
11-03-2025
06:16 PM
by
Content Cleaner
Hey Pat,
Are you running the installer from a TestStand deployment, or the main TestStand installer? If it is the main TestStand installer, where did you obtain it from (disk or online download)?
Also, you can create a log of the installation process by following these steps. If you could follow that process and then attach the log to a reply, we could take a look and see if it provides any additional information about the issue.
Let us know how it goes!
02-13-2014 02:39 PM
Installer is from TS 2013 deployment.
MetaInstaller: Started MetaInstaller version 3.2.0.357: Thu Feb 13 14:34:46 2014
MetaInstaller: Called with command-line: /log log.txt
MetaInstaller: ***Progress Info*** Start: InitializeSystemWideLog. Thu Feb 13 14:34:46 2014
MetaInstaller: ERROR! Developer Error. The following errors were found in your ini file:
MetaInstaller: 1. Missing Section: [Volume Id]
MetaInstaller:
MetaInstaller: Correct the ini file and try again..\IdFile.cpp(123): InstallerError 11006
MetaInstaller: Developer Error. The following errors were found in your ini file:
MetaInstaller:
MetaInstaller: Found while attemping to read the volume id file.
MetaInstaller:
MetaInstaller: MetaInstaller exiting Thu Feb 13 14:34:48 2014. Returning -11006
03-03-2014 01:54 PM
*Bump*
03-03-2014 02:43 PM
Figured it out... For unknown reason(s) 7-Zip was not adding "nidist.id" to my zip file from my Volume1 installation directory. I manually copied the file to the same directory as setup.exe on the test PC and now the error has gone away.
How'd to figure it out? Well, the error said it could not find "Volume Id". I did a text search of the installation files zipped and copied to the test PC and didn't find it. Did a search on the development PC in the installation directory and found it. One of the toughest things to do in software is to provide meaningful error messages.
05-08-2017 01:09 PM
I am trying to install labview 2016 with Windows XP in my machine, but I keep getting the follow error:
12:00 PM
- last edited on
11-03-2025
06:16 PM
by
Content Cleaner
Hi lady1
The last version compatible with Windows XP is the first release of Labview 2012.
