I CAN'T SEE ON THE DISPLAY BUT TESTSTAND IS OPENING
When I run it, it stays like this.
Could you help ?
Message 1 of 8
(2,672 Views)
I can't see on the window *
Message 2 of 8
(2,670 Views)
Hi hkn10, Strange; for clarity:
Are you pushing the OK button on the Login dialog?
If so it looks like someone has defined an Administrator password?
I think you can reset the password by doing this
Message 3 of 8
(2,664 Views)
Message 4 of 8
(2,658 Views)
Message 5 of 8
(2,640 Views)
I did but still have the same problem
Message 6 of 8
(2,627 Views)
Accepted by hkn10
Can you use Windows Explorer to search your machine for the following files and see if the modification date of any of them lines up with when this behaviour started happening? NOTE:  There might be more than one of each file.
FrontEndCallback.seq
frontend.dll
Message 7 of 8
(2,608 Views)
Accepted by hkn10
The problem was solved by running seqedit.exe.
Message 8 of 8
(2,591 Views)
