NI TestStand
取消
显示结果
搜索替代
您的意思是:
I CAN'T SEE ON THE DISPLAY BUT TESTSTAND IS OPENING
已解决!
转到解答
When I run it, it stays like this.
Could you help ?
0 项奖励
1 条消息(共 8 条)
2,671 次查看
I can't see on the window *
0 项奖励
2 条消息(共 8 条)
2,669 次查看
Hi hkn10, Strange; for clarity:
Are you pushing the OK button on the Login dialog?
If so it looks like someone has defined an Administrator password?
I think you can reset the password by doing this
0 项奖励
3 条消息(共 8 条)
2,663 次查看
0 项奖励
4 条消息(共 8 条)
2,657 次查看
0 项奖励
5 条消息(共 8 条)
2,639 次查看
I did but still have the same problem
0 项奖励
6 条消息(共 8 条)
2,626 次查看
解答
接受人 hkn10
Can you use Windows Explorer to search your machine for the following files and see if the modification date of any of them lines up with when this behaviour started happening? NOTE:  There might be more than one of each file.
FrontEndCallback.seq
frontend.dll
0 项奖励
7 条消息(共 8 条)
2,607 次查看
解答
接受人 hkn10
The problem was solved by running seqedit.exe.
0 项奖励
8 条消息(共 8 条)
2,590 次查看
