NI TestStand
How to pass parameter(Instrument addr) in batch model test
Hi All,
How to pass parameter to the step type in batch model?
For example: test socket = 2, the 1st UUT use the instrument(Addr=10),the 2nd UUT use the instrument(Addr=11),how to pass the addr=11 to the step type?
(3,821 Views)
Accepted by weschen
Hi weschen-
When you refer to 'pass parameter to the step type in batch model', are you referring to calling a subseqeuence and passing a parameter with a SequenceCall step in your client Sequence File?
Also, are you attempting to pass a different address value to the parameter of your subsequence based on the TestSocket Index?
-Jeff
(3,818 Views)
Accepted by weschen
thank you for you help.
use a array for instrument addr, pass the array to the step type,and the array index is define by RunState.TestSockets.MyIndex.
(3,811 Views)
Can You provide us with more detailed information how did you solve this ??
(2,683 Views)
