ā05-06-2008 05:16 AM
| String Value test | ||
Status: |
Failed | |
String: |
Limits: | ||
String: |
Comparison Type: |
Ignore Case | |
ā05-06-2008 09:06 AM
ā05-06-2008 10:25 PM
ā05-07-2008 12:39 AM
Or
you can modify the ReportGen_Html.seq to find and replace "String" with the new text after the return from the DLL call and before inserting into the local report text.
Ray Farmer
ā05-07-2008 12:52 AM - edited ā05-07-2008 12:54 AM
ā05-07-2008 01:20 AM
You can do both by not using the option to change all occurrance, just means you will have to do two FindAndReplace calls.
Ray Farmer
ā05-07-2008 01:23 AM
ā05-19-2008 04:14 PM - edited ā05-19-2008 04:16 PM
ā05-20-2008 12:41 AM
Hi JettR,
Thanks for that, I had forgotten about the language file.
But to add to that, you should be able to add the single entry of STRING = "StringFoo" under [RPT_FLAGGED_NAME] in the CustomStrings.ini in the \USER\Language\English
folder and not change the <TestStand>\Components\NI\Language\English\TestStandStrings.ini.
Ray Farmer
