NI TestStand
How to instantiate TS Engine from C#?
I've got problems with instantiating TS Engine from C#.
What I want to do is a simple C# console application which returns into the console sequence file version number. Basically, I want to write inC# what inLV looks like this.
But I cannot instantiate the Engine by doing: EngineClass Eng = new EngineClass();
Wnat shall I do?
Message 1 of 11
(7,764 Views)
If you look into the example user interfaces, you will see how the engine is retrieved:
First you will need the correct using:
// TestStand User Interface Controls
using NationalInstruments.TestStand.Interop.UI;
and afterward, just call the GetEngine routine and perform what you need to do
NationalInstruments.TestStand.Interop.UI.Ax.AxApplicationMgr.GetEngine().whatever
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 2 of 11
(7,760 Views)
Yes, I've seen this.
But would it work with Console Application Project?
UI is designed to work with WPF (Windows Presentation Foundation), but I want only the console app.
Message 3 of 11
(7,756 Views)
Just take a look at this threads:
http://forums.ni.com/t5/NI-TestStand/Marshalling-the-IEngine-object/m-p/666852
there are a small projects which you might use for your console app as well.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 4 of 11
(7,739 Views)
http://forums.ni.com/t5/NI-TestStand/how-to-create-a-local-object-reference-variable-in-teststand/m-...
Hope now link is visible....
--Signature--
Message 5 of 11
(7,734 Views)
Juergen,
I'd want to say it is visible but I have problem even in the first line. Of course I've referenced the assembly.
I think the difference is I'd like to build Console Application; what you sent was example of WindowsForm Application.
Have a look:
Message 6 of 11
(7,723 Views)
I have just open the example. It is Referencing to TS 4.0 Assembly.
Delete this refernce an point to your TS version on your maschine.
Regards
Juergen
--Signature--
Message 7 of 11
(7,718 Views)
i had done some stuff with the console. I can provide an example an Monday...
Regards
Juergen
--Signature--
Message 8 of 11
(7,714 Views)
Your example works fine on my machine.
Reference was automatically updated.
In your example and in my code I'm refering to the same version.
I think the problem is somewhere else.
I've read http://zone.ni.com/reference/en-XX/help/370052K-01/TOC71.htm but with no real help from it.
Message 9 of 11
(7,713 Views)
Regards
Juergen
O!, That would be great!
Message 10 of 11
(7,712 Views)
