How do I Insert a Fileglobals Variable into a Step Name
Greetings Everyone,
     I'm curious, whether or not it's possible to insert a FileGlobals variable into a Step Name, whether it be an Action, Pass/Fail, Numeric Limit Test, or what have you.  An example would be "Paragraph 1.0 execution # {variable} running" were variable would be an incremental count, whether it be a for loop or any other type of senario.  Thank you in advance for any information that you may offer.
Scott
(4,202 Views)
You can do this dynamically in the Pre-Expression of the Step by using the TestStand API.
Step.Name = "Paragraph 1.0 Execution #" + FileGlobals.VariableName + " Running"
Something like that.  During run time your step name will change to that.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,196 Views)
Accepted by Scott754
Hi jigg,
     Thank for the reply.
     I tried it and Thank you.  It does exactly what I was hoping to do.  Many thanks.
Scott
(4,168 Views)
