NI TestStand
System.Runtime.Serialization.SerializationException
I'm using machine's driver, what is created in framework .NET 4.0.
When calling out methods from this dll by using NI Test Stand I'm getting error:
Error: An exception occurred inside the call to .NET member 'MeasSignal':
System.Runtime.Serialization.SerializationException: Parse Error, no assembly associated with Xml key a2:http://schemas.microsoft.com/clr/nsassem/Measurements.Audio/Measurements.Audio%2C%20Version%3D1.0.1.... SpectrumAnalysis\r
I also tried to call out same method with console application (what I created with visual studio 2010) then everything was working as expected.
Any idea what could be wrong if I'm using Test Stand?
Heiki
(5,812 Views)
Hey Heix,
This looks similar to the behavior described in this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/7B539BFFD0C1666186257B04006FA183?OpenDocument
Just for some more information, what version of TestStand are you using?
Which libray is the method in?
Where is this code stored? (i.e. is it a on the local disk or a network drive)
What kind of file are you calling in TestStand?
Are you trying to deserialize the steps?
Which process model are you using?
Best,
-KP
Kurt P
Automated Test Software R&D
(5,785 Views)
NOTE: Some other alternatives that don't seem to be mentioned in the KB:
1) Put assembly in the GAC
2) Put assembly in same directory as the exe you are running.
-Doug
(5,779 Views)
Thank you very much for your time and help. I was able to get it working. Your advice was exactly what I needed.
Heiki
(5,739 Views)
