Help Needed – Missing Driver Simulation Library in LabVIEW
Hi All,
I’m currently using LabVIEW 2025 Q3 and TestStand 2025 Q3. I’ve just started learning TestStand, and while working on a basic sequence, I noticed that I’m missing the following library file:
instr.lib\Driver Simulation.
Could someone please let me know how to download or install this library?
Thanks in advance!
Message 1 of 15
(1,076 Views)
You are referring to a library which is provided by the official TestStand Training Courses.
It can be installed from the Course Material (Excercises\Driver Simulation API from the top of my head)
Message 2 of 15
(1,069 Views)
Thanks for the info!
I’ve already installed the Simulation API from the official TestStand training course materials (from the Exercises\Driver Simulation API folder), but I still don’t see the library files under instr.lib.
Is there anything else I might be missing or need to configure to make them appear?
Appreciate your help!
Message 3 of 15
(1,052 Views)
i have re-installed the driver but still same
Message 4 of 15
(1,035 Views)
Do you happen to have multiple LabVIEW installation on your PC?
Have you installed via batch (old version) or NIPKG (current version)?
Message 5 of 15
(1,034 Views)
NIPKG Current Version.
Message 6 of 15
(1,027 Views)
Accepted by TheFafnir
The installation does finish without errors ???
Are you sure, it is the LabVIEW, not the Python Package you are installing?
Have you tried un-/ re-install?
Message 7 of 15
(957 Views)
Yes, the installation completed without any errors. However, it didn’t initially appear in the library. I tried uninstalling and reinstalling, and after that, it showed up correctly in the library.
Thank you for taking the time to look into this issue I really appreciate your support!
Message 8 of 15
(942 Views)
I ma also facing the same issue which software did you reinstall?
Message 9 of 15
(582 Views)
Try to reinstall the Driver Simulation NIPKG
Message 10 of 15
(558 Views)
