If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
07-25-2025 05:10 AM
Hi All,
I’m currently using LabVIEW 2025 Q3 and TestStand 2025 Q3. I’ve just started learning TestStand, and while working on a basic sequence, I noticed that I’m missing the following library file:instr.lib\Driver Simulation.
Could someone please let me know how to download or install this library?
Thanks in advance!
07-25-2025 05:51 AM
You are referring to a library which is provided by the official TestStand Training Courses.
It can be installed from the Course Material (Excercises\Driver Simulation API from the top of my head)
07-25-2025 06:32 AM
Thanks for the info!
I’ve already installed the Simulation API from the official TestStand training course materials (from the Exercises\Driver Simulation API folder), but I still don’t see the library files under instr.lib.
Is there anything else I might be missing or need to configure to make them appear?
Appreciate your help!
07-25-2025 07:02 AM
i have re-installed the driver but still same
07-25-2025 07:02 AM
Do you happen to have multiple LabVIEW installation on your PC?
Have you installed via batch (old version) or NIPKG (current version)?
07-25-2025 07:34 AM
NIPKG Current Version.
08-04-2025 05:47 AM
The installation does finish without errors ???
Are you sure, it is the LabVIEW, not the Python Package you are installing?
Have you tried un-/ re-install?
08-06-2025 01:00 AM
Yes, the installation completed without any errors. However, it didn’t initially appear in the library. I tried uninstalling and reinstalling, and after that, it showed up correctly in the library.
Thank you for taking the time to look into this issue I really appreciate your support!
10-11-2025 06:53 AM
I ma also facing the same issue which software did you reinstall?
10-13-2025 04:04 AM
Try to reinstall the Driver Simulation NIPKG
