Getting file with extension .log when using Simple Text Report Model Plug-in
I'm trying to use the Simple Text Report Model Plug-in to generate a .csv file from TestStand 2016. Searching the forum and found that this plug-in is recommended to be able to create such files. When I tried it I found that it creates files with the correct comma separated format but the file extension is set to ".log". Sure I can set it to ".csv" manually but that seems like a unnecessary hassle for me. I have looked through all kind of settings but I can't find where to change this setting to the correct file extension. So, where can I change this setting?
(3,241 Views)
Accepted by j_werner
It looks like it is being pulled from a resource string located here: C:\Program Files (x86)\National Instruments\TestStand 2014\Components\Language\English\TestStandExamples.ini
Look for .log in that file.  If you aren't familiar with resource strings basically it is a feature that allows you to store visual text in ini files so you can internationalize your dialogs if needed.  You can read more about them in the TestStand help.  http://zone.ni.com/reference/en-XX/help/370052P-01/tsapiref/infotopics/app_resource_strings_and_inte...
It looks like the dialog for the simple text example is looking for all text on the Front Panel with TS_ and replacing it with the associated resource string.
Hope this helps,
jigg
CTA, CLA
testeract.com
(3,230 Views)
Thanks! That did the trick. Now I also learned about the resource string mechanism.
(3,207 Views)
Unfortunately, I was a little too quick to consider this solved. I changed the string for "RESULT_FILE_FORMAT" which is the only place I could find that sets the file format. Apparently it only changes the string in the settings dialog and not the actual file extension on the file that it creates.
(3,198 Views)
I finally managed to resolve it. It seems that it is hardcoded in the sequence file "NI_SimpleTextReport_LabVIEW.seq" under the sequence callback "Generate Report Path". There, it calls a VI called "CallBuildPath.vi" and inserts a parameter "Extension" to it, which is hardcoded to "log".
(3,195 Views)
