NI TestStand
Get active result processing configuration in API
Is there a simple way of getting the active result processing configuration during runtime?  I'd like to know in my plugin what configuration is active that it's a part of.  I'd rather not have to read the ResultProcessing.cfg file directly to get this info (but that is an option).
CLA, CTA
Not my tempo... AGAIN!
(6,562 Views)
(6,531 Views)
Are you Rick-Rolling me with the link?... haha.  It takes me back to this page!
Can you provide more documentation as to how this provides the active result processing configuration?  I don't see that in Execution.Report anywhere.
CLA, CTA
(6,523 Views)
Accepted by topic author GarryG
That value is not retained in memory after the configuration is loaded, so I think you will need to get it from the file.
(6,519 Views)
OK.  Thanks, James!  I appreciate you replying.  Now I know for sure.
CLA, CTA
(6,514 Views)
A simple way to access to ResultProcessing.cfg file and read the active plugin configuration using Engine.ReadPropertyObjectFile() API method.
If you are making changes to the file, you will need to call the IncChangeCount() andSaveFileIfModified() API calls at the end of the VI to save the changes.
(5,407 Views)
