NI TestStand
How to pass numeric value in hex format to teststep parameter?
my teststep is a custom c# function that has an input parameter of type Number (byte).
How can i insert the data in hex format? (Step settings + Tab Module)
Can i change the insert-field like in labview to decimal, hex, binary?
Thx
(5,982 Views)
Accepted by topic author OnlyOne
Just use "0x" notation.  For instance, for 10 (decimal) you would put in "0xA".
(5,980 Views)
Hi, Can anybody please tell me ..which reference should i connect to access for the following properties of test stand UI.
If possible, please direct which ref i should connect to property node so that i can access these properties.
(5,929 Views)
