‎09-14-2005 09:33 AM
‎09-14-2005 01:00 PM
‎09-15-2005 04:53 AM
Ray, I did what you said, i masscompiled everything. Now I receive another error message:
Model Entry Point 'Single Pass' could not be executed.
Error loading step 'myInitStep' of sequence 'MainSequence' in file 'MySequence.seq'
LabVIEW: The VI cannot be executed
Error Code -18002: LabVIEW reported an error. See 'LabVIEW: ' message for more details.
Source: 'TSAPI'
Thanks for your help. Any other Ideas?
- Caribe -
‎09-15-2005 06:40 AM - edited ‎09-15-2005 06:40 AM
Hi Caribe,
this link may help
Are you using the Operator Interface or the SeqEditor?
Regards
Ray Farmer
Message Edited by Ray Farmer on 09-15-2005 12:43 PM
‎09-15-2005 07:17 AM
Thanks for the link! I'll read it and hope I find the solution.![]()
I am using the Seq. Editor (TestStand 3.1)
- Caribe -
‎11-21-2005 06:06 AM
Hi Caribe,
Did you find any solution to this weird behaviour? Even I am facing the same problem! If we set the adapter as
I am also facing -18002 error after mass compiling
If you can share your solution, that would be of great help to me. If i couldnt find any solution, I have planned to revert back to
Thank you,
Sasi
‎11-21-2005 10:09 AM
Sasi,
The LV 7.1.1 RTE replaces the LV 7.1 RTE. I'm assuming you used the following KB to add the registry entry for 7.1.1:
http://digital.ni.com/public.nsf/allkb/785F5D06B7A1495086256F700076AEAD
If you delete the 7.1 folder, it will no longer show up as a choice. TestStand doesn't care if it is 7.1 or 7.1.1 in this selection, the behavior is the same.
As for the -18002 error, are you deploying your VIs? I would not expect the RTE to work with most VIs until they have been deployed.
Allen P.
NI
‎11-22-2005 11:13 PM
Hi Allen P
Thanks for your reply. Yes I did the runtime engine registry changes as per the given link. I still see the problem when I set the
Thanks again!
Thank you
Sasi
