NI TestStand
Different number of testsockets - How to change with expression?
i have two sequence files which are using two models. The models are set in:
Edit -> SequenceFileProperties -> Advanced
Now i need to run the first sequence with only 1 socket and the other sequence with 2 sockets.
But it seems that Configure + ModelOptions is a global setting which is valid for all models.
Question is:
How can i do it that model1 is always executing with one socket and the other model with two sockets?
Can i add here simply a step into the SequenceFileLoad of the model(s)?
If yes - what is the expression to change the sockets?
Message 1 of 11
(3,151 Views)
You can specify Sequence File specific Model options by overriding the ModelOptions callback and set the value of ModelOptions.NumTestSockets
Santhosh
Soliton Technologies
Message 2 of 11
(3,149 Views)
Accepted by topic author OnlyOne
Thanks.
How can i do this change directly in the model sequence?
So the one model should ALWAYS run with one socket and the other model always with two sockets
Currently in the model the Parameters in "ModelOptions" displays NumTestSockets = 4
Message 3 of 11
(3,144 Views)
Could you share how you made it?
Message 4 of 11
(2,155 Views)
Not solved yet.
Still changing it manually each time the model changes.
Message 5 of 11
(2,143 Views)
santo_13 has described how to do it using the client sequence file.
If you feel confident enough to modify the process model, this should have given you a hint on how to achieve this in the model file directly.
Message 6 of 11
(2,139 Views)
The example of santo_13 is not working.
When i add this Callback to a sequence with NumTestSockets = 4 then it still executes only 1 socket as it is defined in the menu -> Configure -> ModelOptions -> Number of Test Sockets
Message 7 of 11
(2,126 Views)
I confirmed that it does work:
  • Set Model to batch
  • Change Model Options to 1 Socket in Configure > ModelOptions > Number of Test Sockets
  • Add ModelOptions callback to the client sequence
  • Edit the ModelOptions sequence and add a single Statement Step
  • In the Statement step, set expression to "Parameters.ModelOptions.NumTestSockets = 3"
  • Run sequence and see that 3 socket executions are started and prompt shows 3 sockets
Message 8 of 11
(2,118 Views)
Same here.... maybe I should've read this thread first before firing up TestStand 😉
BTW: this exact procedure is used in an excercise in the Developing Test Programs using TestStand
Message 9 of 11
(2,103 Views)
Works here also. I  didnt set the extra statement at the first try as the variable "Parameters.ModelOptions.NumTestSockets" is already set to 4 after insterting the callback.
How can this be transfered direct into the modelsequence so that
Batchmodel_A.seq is set fixed to 1 socket and
Batchmodel_B.seq is set fixed to 5 sockets?
I dont want to add the callback to all test-sequence-files.
Message 10 of 11
(2,096 Views)
