Different number of testsockets - How to change with expression?
i have two sequence files which are using two models. The models are set in:
Edit -> SequenceFileProperties -> Advanced
Now i need to run the first sequence with only 1 socket and the other sequence with 2 sockets.
But it seems that Configure + ModelOptions is a global setting which is valid for all models.
Question is:
How can i do it that model1 is always executing with one socket and the other model with two sockets?
Can i add here simply a step into the SequenceFileLoad of the model(s)?
If yes - what is the expression to change the sockets?
Message 1 of 11
(1,326 Views)
You can specify Sequence File specific Model options by overriding the ModelOptions callback and set the value of ModelOptions.NumTestSockets
Santhosh
Soliton Technologies
Message 2 of 11
(1,324 Views)
Accepted by topic author OnlyOne
Thanks.
How can i do this change directly in the model sequence?
So the one model should ALWAYS run with one socket and the other model always with two sockets
Currently in the model the Parameters in "ModelOptions" displays NumTestSockets = 4
Message 3 of 11
(1,319 Views)
Could you share how you made it?
Message 4 of 11
(330 Views)
Not solved yet.
Still changing it manually each time the model changes.
Message 5 of 11
(318 Views)
santo_13 has described how to do it using the client sequence file.
If you feel confident enough to modify the process model, this should have given you a hint on how to achieve this in the model file directly.
Message 6 of 11
(314 Views)
