NI TestStand
TestStand Path Reference for Labview Actions in Sequence
I have a sequence file that uses absolute paths for all the Labview Steps. Is there a way to change all the references in the sequence to a new path or a relative path?
(535 Views)
You mean like programmatically?
(530 Views)
You could use Search and Replace to remove the absolute part of the path.
(517 Views)
