NI TestStand
Deployment runs into an internal error NI installers
When I try to deploy my system in TSv4.1.1, the deployment runs into an internal NI installers problem. Error in deployment status log is "An internal error occurred involving an installer function.  This type of error usually involves a problem with one or more National Instruments Installers.  For more information open the following log file:
...\Temp\Detailed_Installer.log (path replaced). " I can't find any suspicious in that file. I can even find error line in status log stating "Error Code:-603 Read Registry Value STR.vi".
What I have done is that I have upgraded from TSv3.5 to TSv4.1.1 which is now running in a new computer. I use the same .tsw file as in v3.5. I have verified and I suppose all files in .tsw have correct paths according to changes made from 3.5 to 4.1.1. I use some old DLLs compiled in CVI 8.x included in .tsw.
I have even tried a create a new deployment file without any further success.
I even get the internal error message window above when I access installer options tab and drivers and components window after pressing OK or cancel button.
any help ?
regards,
petri
(3,034 Views)
hi,
Attached a status log from a new workspace with a project and sequence file. Deployment is as well a new.
I can't find *.vis from harddrive.
Installation is FDS from NI developer Suite fourth Quarter 2008 DVD.
regards,
petri
Starting Log.
Error occurred
Error Code:-603
Starting Analysis
Starting to process workspace file
Workspace Processed
Finished Analysis
Error occurred
Error Code:-30
TestStand - Deployment Utility Splash Screen.vi >> TestStand - Distribution Wizard GUI.vi >> TestStand - Additional Components Dialog.vi >> TestStand - Reselect Meta Installer Products.vi >> TestStand - Get Dependencies of TS Engine.vi >> MDFProdPreview_AddProduct.vi
{95C82647-A6CB-492F-A5A9-66A282CAD7F3}
(3,030 Views)
