05-08-2008 08:26 AM
05-09-2008 01:29 AM
05-12-2008 05:09 AM
05-13-2008 12:58 AM
Hi Clint,
At the monent i try to get the example(shipped with ni-dmm and LV8.0 ) running on my TS4.0
but i have also installed LV8.5 on my maschine. So TS tries open it with 8.5 ![]()
be patient !
What i want to mention in my upper answer was that it is running on my maschine
with the example in screenshot.
greetings
Juergen
05-13-2008 05:35 AM
03-24-2009 10:15 AM
This post is kind of old but I was just having this problem, too.
The "Measurement Type" input is number, not a string. When the text is selected as "DC Current" it's interpretting the "Current" part as some global setting. Instead, delete the garbage and just type in "2" for DC Current and "3" for AC Current and click outside the box. The text should come up.
03-25-2009 11:14 AM
jmacd,
I have not tried the files above yet, so I was unsure about your post. Are you still experiencing a problem, or explaining what worked for you? Thanks!
03-25-2009 11:40 AM
I was experiencing the problem and the above post is the explanation of how I fixed it.
