The Device Name is going to be the same as the GPIB Resource, in this case "GPIB::5". The Session number is a number that is used to refer to an internal session to that device. It needs to be populated by TestStand when it is an output. On the first VI that requires the VISA reference as an input, uncheck the Default value checkbox, clear the value for the container, and put your station global in the Device Name field. Set the session number to 0. If you wish to keep the session open between calls, make sure your VI passes a VISA reference as an output. You can then save this reference as a Local variable of the type LabVIEWIOControl. Then pass that variable into the VISA Reference input on future VIs. That should work!
Allen P.
NI
Message Edited by AllenP on
01-31-2008 02:36 PMMessage Edited by AllenP on
01-31-2008 02:40 PM
