NI TestStand
Database logging
Hello, I'm using teststand 4.0. My question is, how can I add my input data in the database. I have a User Interface that sends Input to an instrument and this will send this input to an instrument that is calibrated. Now I do have the data from high and low limits, I have the data that I read out of the calibrated instrument(this seems to be all standard in TS) logging in the database but I can't get it to also log the input data. I do need some instructions how to add additional data in to my database.
thanx, dennis
(3,212 Views)
Hello Dennis,
There are alot of different ways to add additional data to your database.
Below you can find several Tutorials/knowledge bases that will help you to do this:
http://digital.ni.com/public.nsf/allkb/F5ADBC61222343B586256CE00055E6D6
http://digital.ni.com/public.nsf/websearch/D30EC9BBA0D740C286256C760049DABD
http://digital.ni.com/public.nsf/allkb/D44A2FC939D893C386256D1A0078D013
http://digital.ni.com/public.nsf/allkb/4A6D56D1EE1CCDEA862570B600015C9D
http://www.ni.com/white-paper/3604/en
These are also the documents I used when I started to work with TestStand.
Also this document might be handy if you want to completely start from scratch:
http://www.ni.com/white-paper/6484/en
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,198 Views)
Thanx.
(3,159 Views)
