NI TestStand
Cannot add array item to 1D array
Good afternoon,
This is for Teststand 4.2
I have a LabView module in my sequence which takes a 1D array of "parameters" and outputs a 1D array of "results". The problem is I cannot add an Array item to Parameters, but I can add an array item to Results without a problem.
It seems obvous that this may be because parameters is an input, and results is an output.
But next to this module,I have another (imported by a different developer), calling the same exact VI that allows parameters to be added to the array.
Can somebody help explain why this occurs and what I am missing?
Thanks.
(4,852 Views)
Accepted by kennethone
Uncheck the "Default" for your input.
(4,848 Views)
Ok thank you,
(4,844 Views)
