07-21-2014 04:50 PM
I've modified the default stylesheet to remove a lot of the fluff added in the test report. However, I'm stuck trying to remove the subsequence headings from the report. Can anyone with stylesheet experience give me some advice?
I can't modify TestStand reporting at all, only the stylesheet.
I've attached a picure which hopefully should help expain the problem.
-Jeremy
07-22-2014
02:55 PM
- last edited on
10-25-2024
05:00 PM
by
Content Cleaner
Hello Jeremy,
This white paper discusses how to exclude results from reports using filtering. I imagine you could create a filter based on the step values.
