NI TestStand
取消
显示结果
搜索替代
您的意思是:
ApplicationMgr sequence file reloaded
 Hi all,
I'm developing an OI in # with ApplicationMgr object.
I see QueryReloadSequenceFileEvent, it's working and fired when I change a file in SeqEdit.
But I would like to be notifiy by an event when the sequence file has been reloaded.
I don't see any event for that.
Thanks in advance for your help
0 项奖励
1 条消息(共 14 条)
1,917 次查看
Could You please explain what "OI in # " means?
As a suggestion for now , check this link, it might  give You some ideas.
Regards.
0 项奖励
2 条消息(共 14 条)
1,878 次查看
Sorry for the mistake. I mean "Operator interface in C# language"
Thanks for your help
0 项奖励
3 条消息(共 14 条)
1,874 次查看
No problem. So as I understood You just need a popup window created.
Here You can find link for it in C#, and here for LabVIEW.
Regards.
0 项奖励
4 条消息(共 14 条)
1,864 次查看
Thanks for your help. But I don't need a popup windows.
I need to be notified when the sequence file has been reloaded when it has been modified by another application.
0 项奖励
5 条消息(共 14 条)
1,857 次查看
So can You describe what kind of notification You want to receive?
Regards.
0 项奖励
6 条消息(共 14 条)
1,849 次查看
When I modify a sequence file out of OI, the event QueryReloadSequenceFileEvent is raised.
This event is raised just before sequence file reloading.
Does it exist an event raised after the sequence file reloading.
I hope I'm clear.
0 项奖励
7 条消息(共 14 条)
1,845 次查看
Okay, check this link, I think it's what You are looking for.
Especially check this one: PostMainSequence.  Even though this are for Batch of Sequences, but I guess it might work for one sequence.
Regards.
0 项奖励
8 条消息(共 14 条)
1,820 次查看
Thanks for your reply.
But I 'm speaking about Operator interface in C# (.NET) and I'm looking for an event on OI side, not on sequence side.
0 项奖励
9 条消息(共 14 条)
1,815 次查看
For better understand, could You please send Your "Operator interface" screenshot ?
Regards.
0 项奖励
10 条消息(共 14 条)
1,812 次查看
