NI TestStand
Log VI path in TestStand Database
I am trying to edit my TestStand database schema to have a column that records the VI file path of any labview step that is called.  I just don't know what I need to put in the "Value to log" field to achieve this.  For example to log the step name it has Logging.StepResult.TS.StepName but I don't see any variables in the expression browser that look like they would return the file path.  I know some variables don't exist until the sequence is actually executing.  I image that might be the case here.
Does anyone have experience with this and might know what the expression should be?
I also would guess I need some kind of precondition for it as well so it doesn't error out on non-labview step (without a path)?
Thanks in advance,
Torry
Edit:  I did try Step.TS.SData.ViCall.VIPath already but it didn't work.  I think it needs to be something in the Logging. context, but I am not sure.  I haven't done much work with schemas.
Message 1 of 1
(1,024 Views)
