Active X server errors TestStand to LabVIEW
I have LabVIEW 7.1 code called by a Test Stand 3.0 distribution (Full TestStand not installed) running on an XP Home Edition OS.  The code runs fine for a while then starts generating "LabVIEW Active X server errors.  I have not created any specific code to reference this so it must be in the TestStand / LabVIEW interface.  Any thoughts on this??
Jack Ferguson
(2,922 Views)
Hi Jack,
Is there a more specific error message or error code to go along with that? Are you using one of the NI Operator Interfaces to run your sequences or are you using the Sequence editor for debugging?
Pretty much all of the Operator Interface uses ActiveX, it is the main component that allows other languages to communicate with TestStand.
What are your code modules doing? Is there any interaction with software other than TestStand? Do the VIs work if run outside of TestStand for an extended period of time?
Let us know and we'll get it figured out. Thanks Jack,
Dan Weiland
Applications Engineer
Dan Weiland
(2,896 Views)
