06-24-2009 10:42 AM
I have a custom PreBatch callback in TS 4.0 that populates serial numbers, part numbers, etc. for the UUTs being tested (using a Batch model). These variables are found in the PreBatch parameters. However, I cannot figure out how to access these values in other callbacks (SequenceFilePostStepFailure, for example).
In the PreBatch sequence, I can access the serial number for UUT4 using Parameters.ModelData.TestSockets[4].UUT.SerialNumber. But I cannot find the ModelData object when not in PreBatch and have tried looking in root, runstate, main, sequence, etc., without any luck.
Any thoughts?
Chris
06-24-2009 10:48 AM
You can find it at:
RunState.Root.Parameters.ModelData
It will only exist at runtime and only when you are actually running using the batch model.
Hope this helps,
-Doug
06-24-2009 11:27 AM
Perfect, exactly what I needed. For others who come across this question: it only exists at runtime and therefore doesn't show up in TestStand's auto-complete when typing it in. But I ran it and it correctly accessed the variables.
Thanks Doug!
Chris
02-26-2020 03:02 AM
In Teststand 2012, Batch Model, I try the solution in MainSequence unseccessfully !
As I run to the step to use "Runstate.root.parameters.ModelData.TestSockets[0].UUT.SerialNumber to Access the TestSocket_0 's SerialNumber , An Error appears for unknowed parameter Runstate.root.parameters.ModelData . Does someone has a seccessful demo for it.
