NI TestStand
ActiveX TestStand python - set environment (.tsenv)
Hi guys,
I found how to execute sequence from python via ActiveX object.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LpMSAU&l=cs-SK
But I would also like to set environment.
Something like /env argument for command line:
https://zone.ni.com/reference/en-XX/help/370052W-01/tsfundamentals/infotopics/startup_opt/
How can I achieve this?
(3,937 Views)
Here's an older thread about this that might be useful
https://forums.ni.com/t5/NI-TestStand/How-to-specify-environment-when-using-custom-interface/td-p/36...
It should be a similar process to do the same thing with Python
https://www.linkedin.com/in/trentweaver
(3,903 Views)
thanks a lot 😀
Now I knew how it works,
but not have a clue how to call this COM object from DLL in python.
(3,870 Views)
Accepted by topic author mirrko
I was able to get it to work by using the CLSID:
import win32com.client
tsEngineInitSettings = win32com.client.Dispatch("{DEF1D36A-327A-487D-876D-816D0D171888}")
tsEngineInitSettings.SetEnvironmentPath("C:\\Users\\Demo\\Desktop\\myEnv.tsenv")
tsEngine =  win32com.client.Dispatch("TestStand.Engine")
print(tsEngine.GetEnvironmentPath())
(3,850 Views)
