07-30-2020 11:17 AM
Wes,
Thanks for the extra details. I checked the "*Users\Public\Documents" directory and it was created/modified around the time of the successful NIPM installs. Windows 10 also abstracts/references this directory as 'Public Documents' (see photo). Also the registry 'Common Documents' looks good (photo attached).
Perhaps for clean Windows 10 installs a registry update and/or manual creation of this directory is needed to help the NIPM scripts execute? Seems like a plausible solution for this first run / setup.
Cheers,
Andrew
08-29-2025 03:00 PM
I'm trying to follow these steps as I'm encountering the same problem myself. Can you please tell me where the commands/lines contained in the linked post (to configure the package manager to generate and save MSI logs) are to be entered? Is it in NIPackageManager.exe.config or somewhere else? Thanks.
