NI Package Manager (NIPM)
Error occurred while installing a package
When upgrading from LabVIEW 2019 to 2020 I got the following error:
An error occurred while Installing a package: ni-daqmx-runtime-core (20.0.0.49152-0+f0)
Now I get the same error after uninstalling all NI software and installing LabVIEW 2019. LabVIEW 2017 installs and works normally.
I tried install connected and disconnected from network - same error either way.
Everything works normally on my home computer when installing LabVIEW 2020 and LabVIEW NXG 5.0
error log attached.
Message 1 of 11
(19,912 Views)
Accepted by topic author sfrosty
Solution was to wipe out laptop and re-install windows 10, LabVIEW 2020, and LabVIEW NGX 5.0. Everything now works normally.
Message 2 of 11
(19,859 Views)
Yikes!
I'm having a similar problem and REALLY hope that's not the only solution! Glad you fixed it.
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
Message 3 of 11
(19,600 Views)
Getting this error:
An error occurred while installing a package: ni-package-manager-deployment-support (22.5.0.49189-0+f37)
Additional error information:
An error occurred while installing the MSI at 'ni-package-manager-deployment-support.msi'.
This is a fresh install of Windows 10 so this CANNOT be the only solution. Any ideas?
Message 4 of 11
(17,406 Views)
Can you retry with logging activated? An installation log makes diagnosis far more easy.
Message 5 of 11
(17,399 Views)
In particular, please enable and post the MSI logs here. Here's how to enable and find those logs:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHe6CAG&l=en-US
Message 6 of 11
(17,381 Views)
Just stumbled upon this topic when trying to fix this issue when installing NI-DAQmx 2023 Q2 on a Win10 64bit system.
In my case this was solved by finding / removing all "National Instrument" entries in the registry editor.
No need to wipe / re-install Windows in my case.
I thought my system was "NI-virgin" but it appeared there were some left-overs from a previous install which I forgot about 😉 Apparently this was interfering with the installer.
Message 7 of 11
(15,291 Views)
Did you just delete the "National Instruments" folder under the registry editor?
Message 8 of 11
(13,727 Views)
Within the registry editor, I did a search on "National Instruments" and removed all related entries and folders.
I cannot recall if this was restricted to one folder.
Message 9 of 11
(13,502 Views)
For my case,  the solution is:
remove NI update and upgrade the NI Package manager to the latest version.
You can reinstall NI update later if needed.
I have no idea of the reason and can not explain it.
Message 10 of 11
(2,287 Views)
