NI Package Manager (NIPM)
Error Installing Offline Packages - LabVIEW 2020 Runtime Engine
Wes,
Thanks for the extra details.  I checked the "*Users\Public\Documents" directory and it was created/modified around the time of the successful NIPM installs.  Windows 10 also abstracts/references this directory as 'Public Documents' (see photo).  Also the registry 'Common Documents' looks good (photo attached).
Perhaps for clean Windows 10 installs a registry update and/or manual creation of this directory is needed to help the NIPM scripts execute?  Seems like a plausible solution for this first run / setup.
Cheers,
Andrew
Message 11 of 12
(976 Views)
I'm trying to follow these steps as I'm encountering the same problem myself. Can you please tell me where the commands/lines contained in the linked post (to configure the package manager to generate and save MSI logs) are to be entered? Is it in NIPackageManager.exe.config or somewhere else? Thanks.
Message 12 of 12
(37 Views)
