NI Linux Real-Time Discussions
changing networksettings
i have to change the networksettings (IP,Subnet,Dns...) from a python RESTAPI.
But i can`t find the configfile on the my 9068 with this settings.
where htis config file?
(4,894 Views)
I just wanted to check to make sure that I understand what you're asking fire: you are creating a RESTful server using Python REST API that allows remote RESTful clients can change the networking configuration of the server.
Is that about what your request is about?
(4,207 Views)
exactly!
(4,207 Views)
The way that would be insulated the best from future updates would be to use the System API C interface.
The interface is described here:http://zone.ni.com/reference/en-XX/help/373242G-01/nisyscfgcvi/ni_system_configuration/
I would then use the ctypes module to work with the .so on the target.
(4,207 Views)
Details on the ctypes Python functionality can be found here:https://docs.python.org/2/library/ctypes.html#module-ctypes
(4,207 Views)
Hi, i use this command`s now:
- /usr/local/natinst/bin/nirtcfg  --print0 --get section=SYSTEMSETTINGS,token=host_name
- /usr/local/natinst/bin/nirtcfg  --print0 --set section=SYSTEMSETTINGS,token=host_name,value=My9068
and it works fine
(4,207 Views)
Yes, that is a reasonable approach, but as NI doesn't document that as a programmatic interface, it is subject to change in future releases.
(4,207 Views)
