07-27-2015 10:30 AM
Is there an updated list for unsupported VIs for the Linux Target? This says the primary software version is 2013. Is there a list for 2014 or 2014SP1?
http://digital.ni.com/public.nsf/allkb/1C16BFEA5262E33E86257A46006FC92B
07-27-2015 10:41 AM
Hey LJHerskowitz,
Likely the internal versioning of the KB document didn't have the primary version updated whenever the contents were updated. Normally the primary version value is set when the document is created (2013 is when we released our first Linux RT controllers, so matches when this document came out) but the document itself has been updated since, you can confirm this with the "Last Updated:" section at the bottom.
This KB is also created as a copy from the Help documentation that releases with the product. With each release of the product, I would look to the RT Module Help if there is anything you want clarification on regarding what's supported. Here is the 2014 version,
http://zone.ni.com/reference/en-XX/help/370622M-01/lvrtconcepts/rt_rtlinux/
